lestex5
#1 Posted : 12 years ago
lestex5
my Frigidaire oven is not heating up I have tested every thing and used and ohm meter and all test good but 1 thing the little red light on the front I tested this lamp with my meter and its not ohming at all this is a Frigidaire oven classic series ... could this be the reason my oven is not heating up??????????? please HELP Its and indicator light that says element light on the front it is 125v
lestex5
#2 Posted : 12 years ago
lestex5
Read more: http://forum.appliancepartspros...-oven.html#ixzz2HoeS6odS
http://forum.appliancepartspros.com
#3 Posted : 12 years ago
Parts for Frigidaire FEF366CCD Range - AppliancePartsPros.com
Here is your wiring diagram.
http://manuals.frigidaire.com/p...pringfield/316255347.pdf
I think the red light you are referring to is for the stove top (hot surface), not the oven.
I am assuming that the stove top elements work OK.
Does the oven stay in pre-heat or does it show that it is ready.
if it stays in preheat then odds are that the control board is toast.
lestex5
#4 Posted : 12 years ago
lestex5
the oven stays in pre heat and never goes to ready
#5 Posted : 12 years ago
Sounds like the control board is toast.
I would check the oven sensor if you have not done it, just to be sure it is OK.
Below is a good link, look at 7, 8, 20 and 21.
http://www.applianceaid.com/electric-range-repair-topics.php
power outage has my oven unable to turn on to reset (Oven Repair (including Ranges and Cooktops))
by Guest about a year ago
I'm New & Did Something Really Dumb With My Oven, Suggestions? (Oven Repair (including Ranges and Cooktops))
by Udon 4 years ago
My Oven doesn't start (Oven Repair (including Ranges and Cooktops))
by davidgonzalezc 10 years ago
My Husband broke my oven! (Oven Repair (including Ranges and Cooktops))
by Wanda Elaine 10 years ago
F1 and E5 code on my oven (Oven Repair (including Ranges and Cooktops))
by kclan4 11 years ago
My oven elements will not work (Oven Repair (including Ranges and Cooktops))
by Billman 11 years ago
I accidentally pulled off my oven door... (Oven Repair (including Ranges and Cooktops))
by bleumoose 12 years ago
IS this the right ERC for my Oven (Oven Repair (including Ranges and Cooktops))
by o2fill 12 years ago
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 12 years ago
Self cleaning killed my oven. Where is thermal fuse at? (Oven Repair (including Ranges and Cooktops))
by Javawagen 12 years ago
My oven doesn't work (Oven Repair (including Ranges and Cooktops))
by David19 12 years ago
Is my oven dead? (Oven Repair (including Ranges and Cooktops))
by Gator81 12 years ago
Shouldn't have cleaned my oven! (Oven Repair (including Ranges and Cooktops))
by tlhutton 13 years ago
Problem with my oven door not closing (Oven Repair (including Ranges and Cooktops))
by REV1842000 13 years ago
why my oven does not turn on? (Oven Repair (including Ranges and Cooktops))
by elbebe2525 13 years ago
