EdP
#1 Posted : Sunday, January 6, 2013 5:47:11 PM(UTC)
EdP
The water delivery tube to the ice maker continues to drip water after filling up the ice maker reservoir. The water delivery tube eventually freezes up and ice making stops. Using a hair dryer to thaw delivery tube, only for it to freeze up again. What is causing the water delivery tube to freeze on this model refrigerator?
#2 Posted : Monday, January 7, 2013 5:24:40 PM(UTC)
Hello,
Most likely the problem is that the ice maker part of the water inlet valve is stuck open. The correction is to replace the water inlet valve.
- The water inlet valve Part number: W10408179
