jake
#1 Posted : Wednesday, August 8, 2007 12:34:35 PM(UTC)
jake
Oven fan goes on and will not turnoff. Advised that the entire clock unit needs to be replaced b/c cannot locate the "one" board that needs to be replaced. The cost of the entire clock unit and labor is almost as much as the cost of the wall oven. :confused:
Admin / APP Team
#2 Posted : Wednesday, August 8, 2007 3:24:34 PM(UTC)
Admin / APP Team
Rank: Administration
Groups:
Jake, can you post the model number?
jake
#3 Posted : Thursday, August 9, 2007 6:37:48 AM(UTC)
jake
Model No. 12-4990-00/04
#4 Posted : Monday, August 13, 2007 9:53:50 PM(UTC)
jake
Unfortunately without the wiring diagram for your oven I can not tell you how the oven fan should work. I was unable to find the wiring diagram for this particular model. If, by any chance, you have it and you are able to post it, it will help a lot.
Wiring diagram needed Tappan Wall oven (Oven Repair (including Ranges and Cooktops))
by Sandman038 2/2/2020 12:54:48 PM(UTC)
Help with 1961 Tappan Wall Oven (Oven Repair (including Ranges and Cooktops))
by chinaclipper 12/17/2013 6:23:44 AM(UTC)
old tappan wall oven (General Talk)
by mckraw342 2/3/2009 5:24:40 AM(UTC)
Tappan Wall Oven Door Problem (Oven Repair (including Ranges and Cooktops))
by florenceshield 1/9/2009 6:35:19 PM(UTC)
old Tappan wall oven needs help (General Talk)
by justice dog 11/13/2008 4:48:42 AM(UTC)
Tappan Wall Oven Temp adjustment (Oven Repair (including Ranges and Cooktops))
by jmdrapeau 9/29/2007 4:19:42 AM(UTC)
