Captain Pete
#1 Posted : Monday, December 31, 2012 4:40:01 PM(UTC)
Captain Pete
Kenmore Seies 70 dryer. Manual dry works fine, but the auto dry cycle does not dry clothes. Want to know what may cause this and what parts are needed to repair it.
#2 Posted : Tuesday, January 1, 2013 2:31:11 AM(UTC)
Parts for Kenmore Dryer 11064742400 - AppliancePartsPros.com
I timed dry the timer motor gets power through Timer Switch 0 TM/WB contacts whenever the motor is on.
In auto modes the timer motor gets power through Timer Switch 0 TM/OR contacts through the heat coil when the coil is turned off.
So first, check that the coil has resistance.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to be on all the time.
If the heating coil is OK, set the timer to mid-scale auto mode and check that the TM/OR contacts are closed..
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
64742400.pdf (257kb) downloaded 7 time(s).
