Washer fills with water then stops. If you lower the water level and turn it back on, it fills back to the correct level then stops. If you open the lid, the washer stops filling, when the lid is closed it continues to fill again. It doesnt mater which setting the washer is on, it does the same thing. I've checked other posts, it seems that the possibilities are the lid swich or the timer. I cant hear the timer running. Any help is much appreciated.
Ok, I took the lid switch out and it checked out ok. However the small white micro switch that's in the same area as the lid switch was bad. If i tap on the white micro switch I can get continuity thru it, unfortunately now the washer will not fill but it will spin. Also, the timer turns but only in the spin cycle, it does not turn if you set it anywhere in the wash cycle. If the bad micro switch has anything to do with that it would be great but im not sure how to test it. Please advise, Thanks!
