my washer, every time in the cycle of motor spining, it stoped and won't spin. However, I can hear the humming sound instead like, "hmmmmmmm" (motor tred to spin but sound like motor stuck with something.) I have already replaced with new motor and then it works first time but it happend again. :( I checked all the parts, (transmission, clutch, brake, rubber couple....) but seems no problem. if this happen, I detached motor and put it back again, then it works again temporary. I suspected the "CAPACITY" but not sure. Any recommendation?? What's capacity doing in the washer??? Thanks,
ljh0205
Groups: APP Team
Hi.
You should check if there is anything jamming the drain pump. See if the motor will run without the pump. The start capacitor assisting the motor start winding to kick in the motor. If you have the multimeter check the capacitor. The rating is on the capacitor.
Simon.
