jmeander
#1 Posted : Friday, November 23, 2012 5:23:22 AM(UTC)
jmeander
A spill went through the vents at the top of the door and now there are drip marks on the window glass. I see a variety of screws attaching the stainless front panel to the door assembly but not sure which are the minimum to remove to access the glass panels.
Google returns countless threads on this same problem with many different stoves. I understand the need to vent the glass but manufacturers should foresee this very common problem and provide easier access, or at the very least, how-to cleaning instructions in the user manual.
Thanks,
jmea
rickgburton
#2 Posted : Saturday, November 24, 2012 2:15:38 AM(UTC)
rickgburton
Take the door off the range and lay it on a flat surface. Remove the screws for the handle and the three screws on the bottom. I think you can get it from there.
