Elise
#1 Posted : Wednesday, August 8, 2007 8:27:07 AM(UTC)
Elise
The machine appears to function properly, it aggitates and the tub spins slightly as it is aggitating however, when there is a full load the the clothes do not move well in the machine (it is not overloaded in the slightest). This can happen if it is slightly more than 1/2 full. It aggitates, but does not aggitate well. It seems the machine cannot handle the load and the clothes are not moving within the tub well.
The only other issue is when you turn the machine on in the regular wash cycle only, the aggitation starts immediately when the tub is filling up with water so I have to put it on another cycle, like permanent press or heavy wash until it fills up with water and then change to the regular wash so it doesn't aggitate during the fill-up of water. Not too much of a concern but the full load issue is.
Thanks!
whirlpool ultimate care II washer help!! (Washer Repair)
by baseballmommy3 11/3/2013 1:08:54 AM(UTC)
Whirlpool Ultimate Care II Washer - stuck agitator (Washer Repair)
by TommyCee 11/10/2012 6:40:46 AM(UTC)
Whirlpool Ultimate Care II washer won't agitate, spin, or drain (Washer Repair)
by dawn74 9/24/2012 8:02:19 PM(UTC)
Whirlpool Ultimate Care II Washer won't Rinse after Wash Cycle (Washer Repair)
by vahanjan 2/4/2012 4:24:49 PM(UTC)
Whirlpool Ultimate Care II Washer will not spin fast (Washer Repair)
by benjm2 4/15/2011 9:34:00 AM(UTC)
Whirlpool Ultimate Care II Washer (Washer Repair)
by Joistman 3/4/2011 7:36:36 AM(UTC)
by susanis 2/7/2011 11:30:49 AM(UTC)
by mccarthyjudi 6/1/2010 6:43:16 PM(UTC)
whirlpool ultimate care II washer (Washer Repair)
by queen_dior 7/29/2009 4:54:26 PM(UTC)
by missfixit 5/28/2009 4:10:53 PM(UTC)
