I have a Whirlpool Fridge model #ed25ue. Recently, the water inlet tube going into the ice maker froze up and is covered with ice. I melted it and the next day the same thing happened. Any help is appreciated. Thanks!
Replace the water valve and that will fix it. Part #2206123
Originally Posted by: rickgburton  Replace the water valve and that will fix it. Part #2206123 Thanks Rick!! Is that something that I can change myself?
Originally Posted by: rickgburton  Yes, very easy to do. Perfect thanks!! One last question..........I opened my freezer and noticed that the water from the ice maker was just flowing and would not stop and the water was overflowing into the ice catch. Will the inlet valve correct this problem as well?
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello. Question. My ice maker fill tube keeps freezing up. I have a whirlpool WRF736SDAM14. I have replaced the ice maker. The fill tube heater wire. The double water inlet valve. At this point I'm. It sure what to do.
