dieseldent
#1 Posted : Thursday, November 1, 2012 11:26:57 AM(UTC)
dieseldent
I have a Jenn-Air s100 the baking element stopped working but the broil element still works. I replaced the baking element but it will still not heat up? What part do you think I need next to repair the problem?
Simon / APP Team
#2 Posted : Thursday, November 1, 2012 1:55:36 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide the complete model and serial number of the unit.
Simon.
dieseldent
#3 Posted : Friday, November 2, 2012 5:11:22 AM(UTC)
dieseldent
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Thanks for your response, its a Jenn-Air S100 Model serial #262426VG
Simon / APP Team
#4 Posted : Friday, November 2, 2012 10:02:04 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the hi - limit thermostat most likely located at the back of the range. If there is no continuity - replace it
Part number: 74009837
Post the results.
Simon.
dieseldent
#5 Posted : Wednesday, November 7, 2012 3:57:02 PM(UTC)
dieseldent
Ok I ordered the part you sugested and installed it. The Bake element still does not work? What do you think the problem is now ?:confused
Simon / APP Team
#6 Posted : Friday, November 9, 2012 1:51:13 PM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Make sure that the oven clock is set to the "manual", turn the knobs to pop out position or what ever it is per instructions to set the clock for MANUAL.
If that is not the case than most likely it's the thermostat or the selector switch.
Both this items are no longer available.
Simon.
P.S. You can return the hi - limit thermostat.
