Thermahell
#1 Posted : Tuesday, October 23, 2012 5:50:01 PM(UTC)
Thermahell
The two left burner has no spark or gas when turn on, the grillde and two right burner works fine. Is this a simple fix or should I call a appliance repair company?
#2 Posted : Wednesday, October 24, 2012 4:44:03 PM(UTC)
Originally Posted by: Thermahell Go to Quoted Post
...Is this a simple fix or should I call a appliance repair company?...
You have to have a simple multimeter and know how to use it. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - http://forum.appliancepartspros...continuity-ohmmeter.html
Let us know when you will be ready.
Thermahell
#3 Posted : Wednesday, October 24, 2012 4:49:59 PM(UTC)
Thermahell
I have a fluke digital multimeter and do know how to use it. But have never repaired appliance.
#4 Posted : Wednesday, October 24, 2012 6:56:14 PM(UTC)
Very good! Let's moving. Perform the troubleshooting as described in the attached file and post the results.
Here are the breakdown diagrams and Parts for Thermador PRG364GLUS Range - AppliancePartsPros.com
File Attachment(s):
XLO burners troubleshooting.doc (267kb) downloaded 73 time(s).
Thermahell
#5 Posted : Sunday, October 28, 2012 9:11:09 AM(UTC)
Thermahell
Well did the test, Im not getting the voltage that I should be getting. I decided to jump the 120v to the 3rd pin from the left of the potentimeter and the burner lit right up. So Im assuming my SMC is bad, when I went to the order page I see that there are 2 to choose from. Which one am I suppose to order?
#6 Posted : Monday, October 29, 2012 2:53:03 PM(UTC)
Which part did you call "SMC"?
Thermahell
#7 Posted : Wednesday, October 31, 2012 6:05:10 PM(UTC)
Thermahell
Sorry, I meant simmer control module. I see two to choose from and don't know which one to order for my stove.
#8 Posted : Thursday, November 1, 2012 1:10:13 PM(UTC)
I would recommend to order the simmer control kit which contains of the simmer control module and 2 potentiometers.
- The simmer control kit Part number: 497234
Part number: 497234
