Hello when ever I use large loads seems to leak water, will not leak if it is empty, any common issues to look for, about 14 months old.
Does it try to spin during the agitation? If it does then the problem is a bad transmission. - The part number for the transmission is AP2046402 Gene.
Gene I am not sure, It does it once every 2/3 loads, so I have not even seen where the water is coming from, takes a while to get to the cycle and sitting there several times waiting for it to leak gets real boreing, when it goes though the cycle and does not leak. Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Does it try to spin during the agitation? If it does then the problem is a bad transmission. - The part number for the transmission is AP2046402 Gene.
