discgolfdoug
#1 Posted : 12 years ago
discgolfdoug
I've replaced the thermal fuse, high and low limit thermostats and heating element. Heated for one load, then shut off breaker, then when breaker was switched back on--no heat again. All parts show continuity.
Any ideas what to try??
#2 Posted : 12 years ago
I cannot find any tech info on the given model number, please check it.
There is info on a 5570.
Need more info.
What was the original problem?
You said "shut off breaker", did you shut it off or did it blow the machine trip the breaker?
When you checked continuity did you get actual resistance (ohm) readings?
Since the breaker shut off I would start by checking the voltage. The heater requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
