Hello!
I have a gas central air heater/AC that is acting up. We turned on the heat the other day but it wouldn't light =/
Every year I have to clean the flame sensor and all is well, unfortunately the ignitor isn't even glowing this time.
I figure I may have a cracked ignitor, and want to take a multimeter to it to confirm, but am not sure exactly "where" to test. Would I just put it on the positive and negative cables coming from the computer?
thanks!
I pulled the ignitor and sure enough it has a crack, also showing "infinite" resistance when I check ohms
I'd like to make sure my wires are working properly before ordering my replacement ignitor and calling it a day though, Should I just turn the heater on and check the voltage of the two wires that go into the ignitor? (sounds dangerous)
thanks!
