techdowe
#1 Posted : 17 years ago
techdowe
Where to start?
Dryer seems to take a very long time to dry clothes if at all.
What I have done.
1. Cleaned vent duct and made sure that exhaust hose was free of kinks.
2. Run dryer disconnected from exhaust duct (just in case)
3. Measured power at wall socket 220VAC between both lines 120VAC
each line to Ground.
4. Shined flash light down lint trap saw nothing put hand into dryer exhaust
port as far as I could found nothing.
5. Examined heater element through view hole on top appears that all coils
are turning on.
6. Checked continuity SP? across the two heater leads while disconnected
from wiring. checked good.
7. Observed heaters while unit is running. Found the turn on and off. This
is because the cycling thermostat Does that sound right?
8. Found that while heaters are running they draw 22.5 amps per leg.
9. Checked Thermal fuse is good.
10. I checked another switch/Thermostat I think it was high limit. good
continuity.
I hope this description will help you have a good picture of my problem and thanks for all the help.
RegUS_PatOff
#2 Posted : 17 years ago
RegUS_PatOff
and it used to work better ?
did you check/clean the rest of the exhaust vent (to the outside) ?
try it with the vent disconnected.
is there good air-flow out the vent ?
check the air temp out the back of the dryer (with a meat thermometer) with the dryer empty
(wet clothes will take a long time for the dryer to heat to the limits)
it should be about 150F
Samsung dv220agw - heating problem (Dryer Repair)
by jjandrews222 4 years ago
Electric Admiral Dryer heating problems. (Dryer Repair)
by ShaneBurle24 7 years ago
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 8 years ago
Dryer heating problem (Dryer Repair)
by Doehr 9 years ago
Oven Heating Problem (Oven Repair (including Ranges and Cooktops))
by Jman1 9 years ago
Roper dryer heating problems (Dryer Repair)
by laurencp72 9 years ago
Kenmore Elite HE3 gas heating problems (Dryer Repair)
by karl1970 10 years ago
Intermittent heating problem with gas dryer (Dryer Repair)
by David L. Mandel 11 years ago
Diagnosing Heating Problem (Dishwasher Repair)
by glmoore0001 11 years ago
oven heating problem (Oven Repair (including Ranges and Cooktops))
by 9point1 11 years ago
LG LSE3092ST Oven Heating Problem (Oven Repair (including Ranges and Cooktops))
by parabola 11 years ago
maytag stacked Dryer heating problem. (Dryer Repair)
by yudule 12 years ago
by HOLLYTIM 12 years ago
Need more help with dryer heating problems (Dryer Repair)
by Steves9411 12 years ago
Heating Problem Issues (Dryer Repair)
by dmikel12 12 years ago
