cindystarr
#1 Posted : Friday, September 28, 2012 2:57:39 PM(UTC)
cindystarr
Dryer stopped heating. Drum turns, fuses all ok. I replaced the heating element and the thermostat and still no heat??? What gives?
#2 Posted : Saturday, September 29, 2012 1:56:43 AM(UTC)
I cannot find any info on the given model number, please check it.
I would check the power first.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker and the heating element requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Whirlpool Dryer Not Heating (Dryer Repair)
by Frustrated42 11/8/2015 7:21:05 AM(UTC)
by handygirl67 3/12/2015 1:14:03 PM(UTC)
whirlpool dryer not heating nor timer advancing (Dryer Repair)
by bladrnr 12/26/2013 12:39:41 PM(UTC)
electric whirlpool dryer not heating up (Dryer Repair)
by jumpnchuck 10/30/2013 6:31:51 PM(UTC)
Whirlpool dryer not heating or turning (Dryer Repair)
Belarus splumer 9/22/2012 10:05:44 AM(UTC)
Whirlpool Dryer not heating (Dryer Repair)
by ValpoMan 9/17/2012 3:34:11 PM(UTC)
by rdmousaw 8/7/2012 1:03:50 PM(UTC)
Whirlpool dryer not heating up (Dryer Repair)
by MKrieck 7/22/2012 6:37:03 PM(UTC)
Whirlpool Dryer not heating well (Dryer Repair)
by rockettme 6/7/2012 9:22:08 AM(UTC)
by moorece8 5/9/2012 5:28:21 AM(UTC)
Whirlpool Dryer Not heating up (Dryer Repair)
by rrussell@erols.com 4/25/2012 12:18:22 PM(UTC)
by Phiphtie 1/4/2012 3:09:19 PM(UTC)
Whirlpool dryer not heating timer not advancing (Dryer Repair)
by mbell418 7/13/2011 8:39:30 AM(UTC)
by scoffman1234 3/16/2011 1:36:37 PM(UTC)
