miguel622
#1 Posted : Thursday, September 27, 2012 9:20:57 AM(UTC)
miguel622
My chest freezer decided in the last few weeks to stop working well for me. I would come out and see if sitting around 15-20F. I turned it off and back on a few times and each time it would work for a day or two then get stuck at 15-20F again. So a few days ago I moved all the food out and into another freezer and put an external temp controller on the freezer. I set it at -5F and it is now holding no problem.
I noticed before the freezer would just run and run and the back wall inside the freezer would get very warm (in the 20's or 30's) while the front inside would be -25F. It seemed to be fighting itself. Well now with the external temp controller both walls are nice and cold.
Is this something with the thermostat or a sealed system issue?
Simon / APP Team
#2 Posted : Thursday, September 27, 2012 12:32:42 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Based on info you provided the cold control should be replaced
Part number: WR09X10059
What do you call "an external temp controller"?
Simon.
miguel622
#3 Posted : Thursday, September 27, 2012 12:35:44 PM(UTC)
miguel622
This is the external thermostat I have been using.
Series TS | Digital Temperature Switch | Dwyer Instruments
Simon / APP Team
#4 Posted : Thursday, September 27, 2012 1:51:49 PM(UTC)
Simon / APP Team
Groups: APP Team
It 's up to you what to use to control the temp.
Simon.
Dryer running too hot... bad thermostat? (Dryer Repair)
by tireshark 6/1/2011 5:42:01 PM(UTC)
