Started leaking lot of water yesterday. Raised appliance and examined closely when running. No cracks or leaks seen anywhere. Hoses and joints are all dry. Leaks only when pump is running. Water collects in between the washer tub and the metal plate (that is right under tub) and falls to floor. Installed a brand new pump - no use; still same leak. Cannot find where exactly it is leaking. Can you help ? Any suggestions ?
