My dryer will turn on, but it will not get hot. I think it is the ignition or the fuse, but I am not sure.
You must check all the thermostats and the fuse in the back of the dryer to see if they are good then if they are not replace it if they are then you will have to test the igniter by removing the plug in the front of the dryer to see if the igniter glows when it is turned on or just test it for continuty if that not your test the flame sensor for continuty if it passes then you will have to replace the dryer coils
