Can anyone help with my dryer..It is about a year and a half old and now won't heat and it doesn't stop running.
The first thing I would check is 240V at the power outlet. If there is nothing wrong with the power then the following parts have to be tested for continuity: 1. The heating element (#17 on the break down diagram) 2. The thermal cut-off (#6 on the break down diagram) 3. The hi limit thermostat (#15 on the break down diagram) 4. The cycling thermostat (#24 on the break down diagram) The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter. - The part number for the heating element is AP3094254 - The part number for the thermal cut-off (including the hi limit thermostat) is AP3094244 - The part number for the hi limit thermostat is AP3131941 - The part number for the cycling thermostat is AP3131939 Good luck. Gene.
What about a Roper RGX5634KQ2, Gas Dryer, that won't heat up and doesn't stop running?
