The evaporator keeps freezing up. I have replaced the defroster heater unit a couple of times but apparently that is not the problem. What controls the defroster heater unit to keep the evaportor unit defrosted?
Originally Posted by: jclisk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The evaporator keeps freezing up. I have replaced the defroster heater unit a couple of times but apparently that is not the problem. What controls the defroster heater unit to keep the evaportor unit defrosted? If its an older unit it is a timer usually in the back of the fridge section , if newer an adaptive defrost control.Also you need to check the defrost thermostat that is connected in series with the heater.
THIS FORUM IS DEAD!!!!!!! |
The model number is MSD2758DRB
