lexusnip
#1 Posted : Friday, August 24, 2012 10:27:21 AM(UTC)
lexusnip
I thought a couple drum rollers might fix the horrendous squeek coming from my dryer but after replacing them I am looking elswhere. The belt appears to me a little worn as a few strands are coming loose but with a flashlight im guessing the tensioner pulley might be the real problem. Or possible a bearing somewhere. Any ideas??
Simon / APP Team
#2 Posted : Friday, August 24, 2012 1:37:09 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's the idler pulley and the shaft.Check if you need both , then order pulley and arm.
The other possibility is motor bearings.
Here is the breakdown diagram Motor drive replacement parts for Maytag MDE9316AYW DRYER- ELE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Squeeky dryer (Dryer Repair)
by julieshaver@bellsouth.net 8/13/2012 4:08:57 AM(UTC)
ear piercing squeeky dryer!!! Help! (Dryer Repair)
by fawn_eyes888 8/31/2010 12:10:36 PM(UTC)
Squeeky Dryer (Dryer Repair)
by tbela 8/21/2010 2:49:11 AM(UTC)
squeeky dryer (Dryer Repair)
by shorembo 8/20/2010 7:12:47 PM(UTC)
by jooey2 7/19/2010 11:24:25 AM(UTC)
by Stonehenge 1/12/2010 4:11:33 PM(UTC)
by Squeeky Dryer 7/1/2009 4:21:34 PM(UTC)
by clayandlin 2/9/2009 9:19:18 AM(UTC)
