jasmineblue27
#1 Posted : Sunday, August 19, 2012 12:56:43 PM(UTC)
jasmineblue27
Need some answers from anyone will to help. My dryer is working fine no issues contoll panel lights, drum turns and no noises. However it will NOT GET HOT. I have replaced the Heating Element and still no heat. Please help if you know any solutions.
jasmineblue27
#2 Posted : Sunday, August 19, 2012 2:35:26 PM(UTC)
jasmineblue27
Please anyone know anything or have any suggestiond for me ????
#3 Posted : Monday, August 20, 2012 2:37:04 AM(UTC)
Replacement parts for Frigidaire GLEQ942CS0 Frigidaire/dryer | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...ter/1342003e_sheet_1.pdf
First check the power to the unit.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Next check the hi-limit thermostat.
Should be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Maytag Centennial dryer will not heat up (Dryer Repair)
by 1hkfan 10/31/2012 6:51:34 PM(UTC)
Dryer will not heat up consistently (Dryer Repair)
by GPDIY 1/4/2012 5:21:02 AM(UTC)
Electric Dryer will not heat up (Dryer Repair)
by varn99 6/2/2011 3:26:17 PM(UTC)
by ray2 5/13/2011 7:10:58 AM(UTC)
by Raljac63 2/10/2010 7:15:09 AM(UTC)
Whirlpool Kirkland Gas Dryer Will Not Heat Up (Dryer Repair)
by LITTLE RED ROOSTER 1/29/2010 9:11:39 AM(UTC)
Kenmore Dryer Will Not Heat Up (Dryer Repair)
by mastaone 11/8/2009 12:44:09 PM(UTC)
Dryer will not heat up? (Dryer Repair)
by mel1293 10/3/2009 12:06:09 PM(UTC)
by Steve T 7/9/2009 7:32:03 AM(UTC)
by clemmy 5/19/2009 7:19:42 AM(UTC)
Dryer Will Not Heat Up - Plug Changed recently from 4 to 3 prong (Dryer Repair)
by Seeking Help 1/11/2009 3:04:44 PM(UTC)
Maytag Gas Dryer will not heat up fully - princeton (Dryer Repair)
by brian.frasco@gmail.com 12/26/2008 1:28:44 PM(UTC)
Whirlpoool dryer will not heat up (Dryer Repair)
by ayellis 4/16/2008 6:47:04 AM(UTC)
