Is this black door frame AP3118046 relatively easy to install. The frame currently on the microwave is is cracked and chipped on the bottom so it will obviously need to come off first. It's not mine so I can't see how it's attached. Thanks
You can try to use the instructions attached to the reply. Gene.
Originally Posted by: terryorie Is this black door frame AP3118046 relatively easy to install. The frame currently on the microwave is is cracked and chipped on the bottom so it will obviously need to come off first. It's not mine so I can't see how it's attached. Thanks Thanks Gene. Seems pretty involved. This definitely helps. I appreciate your assistance.
