martha725
#1 Posted : Friday, August 3, 2012 2:11:37 PM(UTC)
martha725
My washer has been falling apart, first the agitator stopped turning with a full load (ok if 1/2 or less) and now it's started leaking. I have checked the hoses and they are fine the water is coming out the bottom of the machine. Is this worth trying to fix?
sidfink43
#2 Posted : Sunday, August 5, 2012 4:47:04 PM(UTC)
sidfink43
Without a model number I am going to assume that this is a direct drive Whirlpool made product and yes, if that is the case it is very much worth trying to fix.
Replace the agitator dogs to fix the agitator problem, and take off the cabinet and you should find out the pump is the problem with the leak. Replace it and for what should be less than $50 in parts you should be fine for a long time. If you want to you can replace the coupling while you are replacing the pump and that should make it last even longer without another repair.
martha725
#3 Posted : Monday, August 6, 2012 6:10:54 AM(UTC)
martha725
Thanks, its model # 110.28822790.
I don't know how to take off the cover to get to the pump, is there anywhere to find info on that?
sidfink43
#4 Posted : Monday, August 6, 2012 7:26:57 AM(UTC)
sidfink43
Here is the part
Part number: AP2907492
and you will see a link to a nice video that will show you how to open it up and get to the pump. If the pump is leaking you should see water around it, or rust on the clips.
It is an easy repair, but it helps to have a helper, but make sure the helper is really a helper and not just a supervisor.
Good luck.
Leaking Washer (Washer Repair)
by midget73 7/27/2014 3:27:00 PM(UTC)
by broonsparrow 11/30/2013 10:15:30 AM(UTC)
Leaking washer need advice (Washer Repair)
by GE Nightmare 10/5/2013 1:54:30 PM(UTC)
leaking washer (Washer Repair)
by ashkdaot 6/25/2013 6:23:18 PM(UTC)
by Jags 12/22/2012 8:37:52 AM(UTC)
leaking washer and won't drain (Dishwasher Repair)
by colt 11/6/2011 2:15:14 PM(UTC)
leaking washer (Oven Repair (including Ranges and Cooktops))
by cheery 11/5/2011 6:14:56 PM(UTC)
Leaking washer (Washer Repair)
by Crowell 9/6/2011 9:11:30 AM(UTC)
leaking washer during filling (Washer Repair)
by bonnetinsurance 8/10/2011 7:44:44 AM(UTC)
by 03svrider 6/9/2011 10:48:37 AM(UTC)
by rcarroll7703 6/1/2011 7:50:27 AM(UTC)
by donandlynn 5/7/2011 7:32:41 AM(UTC)
by Mrkis 1/30/2011 9:09:01 AM(UTC)
by Clueless101 12/27/2010 12:33:13 PM(UTC)
by wirenutt2 12/6/2010 9:44:26 PM(UTC)
