BionicMan
#1 Posted : Friday, August 3, 2012 5:40:56 AM(UTC)
BionicMan
GE front loading washer, stops between each cycle and door unlocks and start button is blinking. Push the start button the next cycle completes and stops, and your must push the start button to continue after every cycle. Have checked pump filter, drain hose, and water delivery systems, hose screen and pumps all working correctly. When checking for error codes the only code reported was E22.
Any suggestions on what to try next would be appreciated.
Door lock switch perhaps?
Flyride
#2 Posted : Friday, April 12, 2013 7:25:01 PM(UTC)
Flyride
Did you find out the reason for the stopping etc. my washer is doing the same thing.
BionicMan
#3 Posted : Sunday, April 14, 2013 4:55:27 AM(UTC)
BionicMan
The problem was isolated too the 2 in 3 Out Water Valve which for this model was part #AP4303282 (WH13X10029) very easy repair, a few screws to remove the valve assembly works beautifully ever since. Good luck
