Whirlpool duet dryer gew9200lw1 :mad: the diagnostics won't come up now it did flash an e3 code 1 time When the dryer was disassembled for testing and then reassembled the unit worked one time and then it was back to dead. do I need the control interface or the main control module? everything else tested out fine I would appreciate knowing which part to purchase thanks
Perform the test #5 as instructed in the attached Tech sheet (page 6) and post the results. Gene.
