My Whirlpool Duet dryer gets very hot and blows the thermo fuse. The fault code was F3E2. I have replaced the thermo fuse, the exhaust thermistor and cleaned the vent. The thermo cut off and the high limit thermostat has conductivity. After I replaced the fuse and the exhaust thermistor, it dried one load then the thermo fuse blew again. I also checked the heating coil and it is not touching the housing and nothing is warped. What is causing my dryer to over heat and not work. :confused:
What is the complete model number of the dryer?
