My washer will only fill with water, it will not wash, rinse, spin or drain.
If the motor does not sound like it's running check the lid switch. If the motor is running check the motor coupler.
Originally Posted by: ApplianceJunk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) If the motor does not sound like it's running check the lid switch. If the motor is running check the motor coupler. the motor is not running,,,,already did the lid check.
Then check for a bad connections on the wire harness were it plugs into the motor.
If the connections look ok then I would have to start troubleshooting with a multimeter and the tech sheet as it could be a bad timer or motor.
Originally Posted by: ApplianceJunk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Then check for a bad connections on the wire harness were it plugs into the motor.
If the connections look ok then I would have to start troubleshooting with a multimeter and the tech sheet as it could be a bad timer or motor. already changed the timer switch.
Then check for a bad connection on the wire harness were it plugs into the motor.
