The noise sounded like something caught in the pump, so I started to disassemble it. I removed the lower spray arm and then the 8 SS Torx screws holding the top cover. Removing the cover exposed the black plastic impeller that had a 1" hex shoulder and a 1/4" hex head SS screw holding it on. I held the impeller still with a 6-point 1" deep well socket and tried to turn the 1/4" hex head screw with a 1/4" socket on an extension going down through the 1" socket.
The screw didn't really want to turn either way, but since the impeller turned CCW, I figured the screw had to have right hand threads. As I turned the screw CCW, something gave / snapped and now the screw is still tight but the impeller turns freely. I figure I broke what ever held the impeller onto the shaft.
Anybody got any suggestions?
Metman in KY :confused:
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Originally Posted by: Admin / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks for correcting/knowing the right model number. I ordered the Drain & Wash Impeller Kit, but how do I get the old impeller out if I can't get the screw out?
metman Remove the bottom panel and check the pump for a water leak. The most common problem with such pumps is a slow water leak which is invisible and with a long time it causing corrosion to the motor bearing. If this is a case then you have to replace the whole pump and motor assembly. If you still would like to replace just the impeller kit then try to break the wash impeller in pieces. It will make easer to remove the screw. Good luck. Gene.
Thanks Gene,
It's not leaking and breaking both the impeller and the chopper worked. Cleaned up the shaft a little and put her back together as the repair kit showed up Friday. Seems to be working fine.
Thanks again guys
