When I try to use it runs real slow and hums. Will not heat anything. The exhaust fans also runs real slow . Seems like it is not getting the proper voltage. I plugged it into another outlet and same results. I would appreciate any help to my problem. Thank You Bob
Groups: APP Team
Hi.
There is the short some where inside. Take the cover off and remove the contacts from the magnetron. Plug in and turn on. If the humming stops - replace the magnetron. If not - check the diod, capacitor and transformer. Make sure the capacitor is discharged before doing anything.
Thank you. Post the results.
Simon.
