Similar to an ealier post, I can manually lift the foot pedal and the ram will cylce down and back. As soon as I let go it stops running. But it will not cycle down and back by itself like it usually does when I just lift up once on the foot pedal.
any help would be greatly appreciated..
regards, Bob Jones
I have the same problem, when I release my foot from pedal. the ram does not continue to operate as it has done since I have had it. There must be a switch that has gone, can you pplease identify the part I need to order to repair. Thanks JOhn Major
Did you ever get this fixed? What fixed it?
craig
