Elecrolux Or Fridgidare Professional Series Microwave While Running Micrwave It Just Stopped And Would Not Come Back On ( Dead ) . So I Checked Breaker Box And Breaker Had Been Thrown. I Reset Breaker And It Started To Run Again
But ! This Time Then Exhaust Fan Would Not Stop Running. The Fan Buttons Do Not Stop It. Only If I Unplug Bt When Ireplug Fan Starts Again .does Anyone Have Any Ideas ? ? ?
Remove the top grill and open the control panel. Check the hood thermal cut-out (#5 on the diagram) for continuity. It has to be replaced if it's closed. If there is nothing wrong wrong then the control board most likely has gone bad. - The hood thermal cut-out Part number: AP3768244
thanks i will give this a looking into. i will let you know of my findaings
joe rogi
