My Frigidaire front-loader that has run flawlessly for almost five years stuck on pump out at the end of the rinse cycle. Manually turning the timer made no difference. After replacing the timer, when starting at the beginning of the wash cycle it filled, but would not tumble. I replaced the motor speed control board and now it fills, tumbles a few times and pumps out. It then fills and empties through the rinse cycles with no more tumble or spin. Also, the timer is now advancing much faster than it should. HELP!! Thanks, Flamingstar
