AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer will only run on energy efficient setting
This maybe a silly question but how do I check for continuity
I'm getting 0.5 between the two terminals on all settings except the timed dry setting which is reading 1.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Unplug the dryer. Open the control panel. Remove the wires from the "BU" & "BK" terminals at the timer. Check for continuity across these terminals with different timer settings. Post the results,
Gene. Do the same test for terminals "T" & "W", "TM" & "OR" and "TM" & "WB". Do not forget to remove the wires from the terminals before test it. Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Do the same test for terminals "T" & "W", "TM" & "OR" and "TM" & "WB". Do not forget to remove the wires from the terminals before test it.
Gene. Terminal Test, Setting, Result "T" & "W", Air Fluff, 0.5 "T" & "W", Automatic dry, 0.5 "T" & "W", Timed dry, 0.5 "TM" & "OR", Air Fluff, 0.5 "TM" & "OR", Automatic dry, 1.0 "TM" & "OR", Timed dry, 0.5 "TM" & "WB", Air Fluff, 1.0 "TM" & "WB", Automatic dry, 0.5 "TM" & "WB", Timed dry, 1.0
Just my luck...I purchased a new one of these on 9/1 last year. Now I'm beyond the one-year warranty period. Thanks for all of your help Gene. Looks like I'll be ordering another one.
Dryer Repair
