2 Pages<12
hankincm
#11 Posted : Saturday, September 22, 2012 11:37:32 AM(UTC)
hankincm
This maybe a silly question but how do I check for continuity
#12 Posted : Saturday, September 22, 2012 12:09:54 PM(UTC)
You have to have a simple multimeter to run such test.
The following article on our forum will explain in detail how to run a continuity test - http://forum.appliancepartspros...continuity-ohmmeter.html
hankincm
#13 Posted : Sunday, September 23, 2012 12:44:45 PM(UTC)
hankincm
I'm getting 0.5 between the two terminals on all settings except the timed dry setting which is reading 1.
#14 Posted : Monday, September 24, 2012 10:02:34 AM(UTC)
Unplug the dryer. Open the control panel. Remove the wires from the "BU" & "BK" terminals at the timer. Check for continuity across these terminals with different timer settings. Post the results,
Do the same test for terminals "T" & "W", "TM" & "OR" and "TM" & "WB". Do not forget to remove the wires from the terminals before test it.
hankincm
#15 Posted : Tuesday, September 25, 2012 8:41:48 AM(UTC)
hankincm
Terminal Test, Setting, Result
"T" & "W", Air Fluff, 0.5
"T" & "W", Automatic dry, 0.5
"T" & "W", Timed dry, 0.5
"TM" & "OR", Air Fluff, 0.5
"TM" & "OR", Automatic dry, 1.0
"TM" & "OR", Timed dry, 0.5
"TM" & "WB", Air Fluff, 1.0
"TM" & "WB", Automatic dry, 0.5
"TM" & "WB", Timed dry, 1.0
#16 Posted : Tuesday, September 25, 2012 12:21:13 PM(UTC)
Looks like the timer is the culprit.
- The timer Part number: 8299766
hankincm
#17 Posted : Tuesday, September 25, 2012 1:24:50 PM(UTC)
hankincm
Just my luck...I purchased a new one of these on 9/1 last year. Now I'm beyond the one-year warranty period. Thanks for all of your help Gene. Looks like I'll be ordering another one.
Guest (5)
2 Pages<12
