20 Pages«<910111213>»
#101 Posted : Monday, August 30, 2010 12:22:26 PM(UTC)
Originally Posted by: ferdiparra Go to Quoted Post
Can you help me with the part numbers for this dryer? Having trouble reading those breakout diagrams. I am going to test.
1. Thermal fuse
2. Cycling thermostat
3. Igniter
4. Flame sensor
5. Gas valve coils
Thanks for the help.
The thermal fuse Part number: AP3132867
is shown as #59 on the diagram.
Instead of the cycling thermostat this model has the thermistor which controls the temperature inside. The thermistor Part number: AP3919451
is shown as #42 on the diagram.
The igniter Part number: AP3094138
is shown as #4 on the diagram.
The flame sensor Part number: AP2910747
is shown as #48 on the diagram.
The gas valve coils Part number: AP3094251
are shown as #13 & #14 on the diagram.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GGW9250PW1 Gas Dryer | AppliancePartsPros.com
ferdiparra
#102 Posted : Monday, August 30, 2010 3:58:49 PM(UTC)
ferdiparra
Thanks! It was the Thermistor. Pretty simple to test. Saved a boatload I am sure.
#103 Posted : Monday, August 30, 2010 5:17:47 PM(UTC)
troyboat
#104 Posted : Monday, August 30, 2010 7:41:21 PM(UTC)
troyboat
My kenmore gas dryer won't fire. Everything up to the coils is good. I have 113v to the coils and only 16v to the igniter. Is this right? the igniter wont get hot at all. Are the coils shot? Help
krjt
#105 Posted : Tuesday, August 31, 2010 7:00:04 AM(UTC)
krjt
Gene, I got the part and installed it. Turned the unit back on and the ignitor got red and whosh, the gas kicked in like a afterburner. It was truly a sight to behold. Your advice was spot on, as usual. Very happy I am not shopping for a local repairman or shopping for a new unit. The price was definitely right and the labor took maybe ten minutes. Most of it looking for a wrench to take the sheet metal screw off.
Again, thank you for your insight and feedback.
#106 Posted : Tuesday, August 31, 2010 12:57:11 PM(UTC)
You are welcome. Good job!
#107 Posted : Tuesday, August 31, 2010 1:03:45 PM(UTC)
Check the flame sensor for continuity or just bypass it to see if the igniter will glow. If it will, replace the flame sensor.
- The flame sensor Part number: AP2910747
Bob2kat
#108 Posted : Sunday, October 24, 2010 8:54:47 PM(UTC)
Bob2kat
Hi Gene,
The problem is just like the original sender's. Dryer runs but no heat.
I have a Whirlpool LGR6634DQ0 which starts and runs fine, but burner does not ignite. How do I trouble shoot the problem, what order should I take in troubleshooting, and how do I get at each part (i.e. through the front or back, etc.). I recently replaced the timer and it has been working without problem for several months.
Your help is greatly appreciated in advance.
Bob
#109 Posted : Monday, October 25, 2010 4:12:44 PM(UTC)
Hi Bob,
You can use all instructions from the very first page of this thread.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGR6634DQ0 | AppliancePartsPros.com
P.S. I'm leaving for two weeks. So if you'll have more questions, open a new thread and someone else will help you.
Michellez214
#110 Posted : Monday, November 8, 2010 9:06:47 PM(UTC)
Michellez214
I have a Whirlpool/Roper Gas Dryer Model #RGX5634KQ2 . I have tried this on all of the cycles. Sometimes I get heat and other times no heat. I have taken the small cover off of the front and I can see that the igniter glows bright orange but no flame. What would cause this to happen? My husband wont let me buy a new dryer so any help would be great.
