would like to know of proper way to remove belt pully fron electic moter on above washer dryer combo
Hi Joem,
The model number you posted is incorrect.
Verify and repost it, please.
that is the correct model no just ordered dryer parts for sears for above
The model number you posted did not come up anywhere, even on the Sears web site. Probably Sears kept it as a top secret.
I need to replace the belt on my washer combo. My daughter overloaded the washer and I've ordered the belt. How difficult is it to put belt on?
Originally Posted by: ritawcutekids ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I need to replace the belt on my washer combo. My daughter overloaded the washer and I've ordered the belt. How difficult is it to put belt on? Remove the washer front panel by removing the two screws on the bottom and sliding the panel down. You should see how the old belt goes around the pulleys. Gene.
