good morning my problem is my washing machine will not go past the rinse cycle it stops after agitating in the rinse cycle and does not drain and of course does not not go to the spin cycle. What can I do.
Groups: APP Team
Hi. If you manually advance the timer to spin does it spin? If it does - replace the timer Part number: 3951166
Good luck. Post the results. Simon.
I have the same issue, I have a kenmore 600 series sm 9711916 I can move the timer around and all i get is a humming sound. I can not get it to drain the water or rinse, but i can get it to work in the water filling phase
Groups: APP Team
Provide the complete model number, please.
Simon.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Provide the complete model number, please.
Simon. Modle 110.27612600 type 111 ser CU3422918
Groups: APP Team
Hi. Open the cabinet and check wire harness at the timer, motor and capacitor. Using the multimeter check the capacitor. Remove the pump and try without it. There could be something jamming it. Here is the capacitor Part number: 8572717
The pump Part number: 3363394
Use the video clip for the instructions. Thank you. Post the results. Simon.
