croy1021
#1 Posted : Saturday, June 16, 2012 6:02:13 AM(UTC)
croy1021
Defrost cycle stays on too long.
#2 Posted : Saturday, June 16, 2012 1:51:02 PM(UTC)
What is too long?
Defrost on this unit should be about 25 minutes.
croy1021
#3 Posted : Sunday, June 17, 2012 5:59:48 AM(UTC)
croy1021
The year of the unit is 1993. I have not timed the defrost cycle but it is on long enough to melt the ice cubes. It seems to only happen in the summer when the Power Saver/Moisture setting is on the moisture setting.
#4 Posted : Monday, June 18, 2012 12:52:00 AM(UTC)
When I read your reply I thought this will be easy but then I read the last line and that threw a monkey wrench into it.
The way defrost works is that every 6 hours [depends if the timer is wired for continuous or cumulative (compressor on time)] a 25 minute defrost cycle is started. Defrost time is set but the defrost thermostat shuts the heater off once the ice/frost has melted. It opens just above freezing.
So melting ice cubes could be due to a bad defrost thermostat.
Problem is that it also is related to the ambient temperature/humidity and a thermostat problem should not be affected by this.
I would start by checking the freezer temperature. It should be between 0 and 5 degrees F.
Check that the condenser coils under the unit are clean.
Check that the vents in the kick plate and rear cover are clean.
Check that the condenser/compressor fan is on whenever the compressor is on. Also that the fan blade is clean.
Check the door seals.
Defrost Stays on too long (Refrigerator & Freezer Repair)
by capriole 6/14/2012 9:36:43 AM(UTC)
GE freezer defrost stays on too long?? (Refrigerator & Freezer Repair)
by rawaldrip@aol.com 1/18/2011 6:44:18 PM(UTC)
