My Kitchenaid Superba MOD# KAWS850LQ0
My washer will stop midway through a wash and make a loud buzzing sound and then quits all together. If you let it sit for a while it will start up again and run fine. Also, it leaks a little around the pump housing. The leak is easy to fix, but I don't know where to start with the other issue. Maybe the leaky pump is causing the other problem?
Any help would be appreciated!
Groups: APP Team
