tomromeyn7
#1 Posted : 13 years ago
tomromeyn7
First time the Dryer is turned on, burner comes on and goes out (stays on for "normal" amount of time). When the burner tries to light again, ignitor glows and occasionally the burner lites. Approximately every 4 or 5 time, the burner lites. Replace the thermostat and thermal cut-off. Coils on burner deflective?
#2 Posted : 13 years ago
Most likely the problem is a bad gas valve coils. This is very common problem with all gas dryers.
- The coil kit Part number: 279834
GE profile harmony gas dryer does not heat (Dryer Repair)
by wonder88 10 years ago
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 11 years ago
Dryer does not heat anymore (Dryer Repair)
by yellowsir 11 years ago
Dryer does not heat (gas) (Dryer Repair)
by SCOTT4 12 years ago
Dryer does not heat, but runs, all parts seem to be good (Dryer Repair)
by discgolfdoug 12 years ago
whirlpool duet electric dryer does not heat (Dryer Repair)
by alxholbrook 12 years ago
Kenmore H3 Dryer does not heat (Dryer Repair)
by tim75 13 years ago
Electric dryer does not heat. (Dryer Repair)
by Wtucker 13 years ago
by thabersaat 13 years ago
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 13 years ago
by lingo622 13 years ago
Whirlpool dryer does not heat on medium setting (Dryer Repair)
by redcagle 14 years ago
by nwiccauto 14 years ago
Whirlpool dryer does not heat (Dryer Repair)
by jkaffel 14 years ago
by David schuler 14 years ago
