Hello, my freezer works fine and there is no air coming out of the refridge exhaust. Is this the compressor fan? what should I do to try to diagnoss this!
Originally Posted by: fabricedc Hello, my freezer works fine and there is no air coming out of the refridge exhaust. Is this the compressor fan? what should I do to try to diagnoss this! You'll need to pull the refrig out and remove the back machine compartment cover. The condenser fan will be obvious. If the blade isn't turning and the compressor is running there's a good chance the motor is bad. Just in case here's the part #. Part number: AP4079424
