Water Drops Form On Roof Of Refrigerator. Water Leaking Out From Back Of Light, I Put A Container For Water To Drain And It Gets Frozen. Light Flickers.
Groups: APP Team
HI.
You have the case of clogged condensate drain line. Remove the back panel in the freezer, melt all the ice and unclog the drain. You can use the hairdryer, hot water and patience.
Good luck.
Simon.
If you empty the freezer and pull off the inside back wall under the evaporater coil is a tray that is probabbly filled with ice. clear out the ice and in the center you will see a hole about the size of a dime. Run hot water down the drain hole and when it opens up your problem is solved if it comes back purchase a drain heater. Originally Posted by: GLORY S ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Water Drops Form On Roof Of Refrigerator. Water Leaking Out From Back Of Light, I Put A Container For Water To Drain And It Gets Frozen. Light Flickers.
