chas0073
#1 Posted : Tuesday, May 8, 2012 10:27:28 AM(UTC)
chas0073
Rank:: Member
I've got a Whirlpool LXR6232E that stopped working this weekend mid cycle. It was filled with water and clothes but will not spin at all. I took the clothes out and bailed out most of the water. The agitator appears it wants to turn when I put it on the spin cycle, but it freezes up after moving ~ 1/4" inch.
What should I look for?
Simon / APP Team
#2 Posted : Tuesday, May 8, 2012 11:01:36 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is broken lid switch. Use the video clip fro the instructions. To check the switch open the control panel and install the jumper wire between two outer contacts at the disconnect plug. If the washer starts - replace the lid switch.
The lid switch Part number: 3949247
Here are the breakdown diagrams and Replacement parts for Whirlpool LXR6232EQ0 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
chas0073
#3 Posted : Tuesday, May 8, 2012 11:23:09 AM(UTC)
chas0073
Rank:: Member
Simon, could that still be the case if when I close the lid, or push down on the door sensor I can hear a humming noise, almost like the motor is trying to start under too much load, but there is no load and no movement? I know when the lid is up, no noise is being made at all.
Simon / APP Team
#4 Posted : Tuesday, May 8, 2012 3:07:49 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the motor is humming when the lid is closed, than it's not the lid switch.
First make sure that the options switch is properly engaged.
Then remove the cabinet and bypass the lid switch.
Check the motor disconnect plug contacts and wires.
Check the start capacitor using the multimeter.(The rating is on the capacitor.)
Remove the drain pump from the motor shaft and check if the washer will run.
Pump may be jammed by something exotic like the sock or underwear.
Post the results.
Simon.
chas0073
#5 Posted : Wednesday, May 9, 2012 8:25:15 AM(UTC)
chas0073
Rank:: Member
Took off the pump because I noticed the water wasn't draining super fast. Found a sock and a bra underwire clogging the pump.
Simon / APP Team
#6 Posted : Wednesday, May 9, 2012 9:58:16 AM(UTC)
Simon / APP Team
Groups: APP Team
There you go.
Hopefully you still have the matching sock.
Thank you.
Simon.
scottthefixitguy
#7 Posted : Saturday, April 8, 2017 7:56:33 PM(UTC)
scottthefixitguy
Here is a quick video on how to use a Zip-Tie to fix the lid switch:
https://youtu.be/wkySCkWCjtw
Please let me know how it turns out,
Scott
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
by Jon B 10/9/2009 7:18:00 AM(UTC)
