no power at all. I have checked the breaker and the outlet they were both fine and i can't open it w/out the power on( my clothes are still inside) Please Help !!!!
To unlock the door manually you have: 1. Unplug the power cord from the outlet. 2. Remove the lower toe panel. 3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly. 4. Located on the bottom of the door latch assembly is a tear-drop shaped tab. 5. Gently pull the tab down about ¼” or until a click is heard. 6. The door may now be opened.
The model number you posted is incomplete.
Verify the model number on the door frame and repost it, please.
Thank you very much Gene for your advised i was able to remove my clothes from the washer. The model no is 11047532600. I really apprecite it
