birdman097
#1 Posted : Tuesday, April 24, 2012 12:18:30 PM(UTC)
birdman097
I put a load of laundry in that was way too big and now my washer will not drain water or spin. Would you think that it is a pump or a bad lid switch? I had talked with a handyman who said if you replace the lid switch chances are the pump will need replaced as well. The serial number is cl 1429921 type 111. If the parts needed are the lid switch and pump, what is the cost? Thanks
Simon / APP Team
#2 Posted : Tuesday, April 24, 2012 1:28:53 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Would the washer agitate?
Post the results.
Simon.
birdman097
#3 Posted : Tuesday, April 24, 2012 1:34:15 PM(UTC)
birdman097
Yes the center piece moves and it works up to the point to when it has to drain the water and spin.
Simon / APP Team
#4 Posted : Tuesday, April 24, 2012 2:36:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's the lid switch. Use the video to open the washer. When you will get to the lid switch plug, install the jumper wire between two outer wires and start the washer.
Make sure the jumper is making good connection.
If it starts - replace the lid switch.
The lid switch Part number: 3949247
Her are the breakrdown diagrams and Replacement parts for Roper RAS8445KQ0 WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
birdman097
#5 Posted : Tuesday, May 1, 2012 7:00:53 AM(UTC)
birdman097
Simon,
I just replaced the lid switch and my washer is back to running normal again. Your posts and video were extremely helpful and I would not have been able to replace it without you. Thank you very much for everything. This website is amazing and I am going to spread the word to everyone I know. Thanks again.
Simon / APP Team
#6 Posted : Tuesday, May 1, 2012 8:58:49 AM(UTC)
Simon / APP Team
Groups: APP Team
You're very welcome.
Simon.
Looking for Roper washer repair code (Washer Repair)
Belarus Tim F 3/14/2013 6:19:14 AM(UTC)
