washer will fill and will not turn to the next cycle you can manually make the washer change to drain it but it wont go in any other cycle i was wandering if it was the water level switch or not
if you advance it to wash after proper level of water attained, does it agitate ? if you put it to spin , after draining, will it spin ?
