6 Pages«<456
donlgriffin
#51 Posted : Monday, October 24, 2016 5:58:57 PM(UTC)
donlgriffin
Dishwasher is leaking a lot again. Has Whirlpool fixed this problem with their newer models?
hart3man
#52 Posted : Saturday, December 17, 2016 7:28:54 PM(UTC)
hart3man
Rank:: Member
I had the same issue with a leaking diverter valve on Kenmore Elite dishwasher. I believe the infamous rubber washer that fits over the stem on the diverter valve became enlarged and no longer fit tight. I found the diverter valve and rubber washer on Amazon, saved me from buying the entire sump assy just to get a $6 washer. Search this to find the washer - Oil and Grease Seal TC10 x 18 x4 Rubber Covered Double Lip w/Garter Spring. The 10mm dimension is the inside diameter that fit snugly on the new diverter valve where as my original washer would easily slid on/off. Just thought I would share, might keep somebody from buying the entire sump if you only need the washer:)
svelur
#53 Posted : Thursday, April 20, 2017 7:19:30 PM(UTC)
svelur
The bottom-center of my 20-month old Whirlpool Gold series dishwasher (WDT790SAYM3) was leaking and damaged the wood-work around the cabinets in my kitchen.
The repairman said that he would have to replace the entire bottom assembly costing ~$200 in parts and $150 in labor. This is because, he said the grommet cannot be bought as a separate part.
Thanks to this excellent thread - This is what I did:
1. Removed the diverter motor assembly (white plastic piece with a small motor and 2 sets of wires) by taking out the 2 Torx screws (near the bottom center). Took pictures of the wires and disconnected them.
2. Put the Dishwasher back on it's feet - Removed all the fittings inside
3. Using a flat-head screwdriver, gently pryed out the grommet (around the removed diverter motor shaft) at the center. This took some patience and several tries.
4. Ordered a couple of Whirlpool grommets (Part# AP6016787 or WPW10195677) from AppliancePartsPros.com. It arrived next day!
5. Put the new grommet back on - Note that the groves (double-lip) of the grommet should be facing away from the motor unlike some comments in this thread.
6. Used some silicone grease on the motor shaft and put-back the motor, screws, and connected the wiring.
7. I just tested the dishwasher - no more leaks!
Another tip - Just put a shallow pan under the dishwasher and use a water sensor alarm like this: Re-Useable Water Leak Alarm-RWD21 - The Home Depot
This will help detect water leaks before it destroys your flooring.
Note that this grommet is a "Metric Oil Seal - Dual Lip with a Garter Spring - 10 mm Shaft, 18 mm OD, 4 mm Width". See details here: https://www.motionindustries.com...tDetail.jsp?sku=07089658
For proper installation, the seal lip should point towards the medium being contained - water, in this case.
This is a bad design - Whirlpool needs to fix this or at least send out bulletins to the owners and all licensed technicians.
Good luck!
Cheers,
Shashi
tb19
#54 Posted : Sunday, July 23, 2017 1:51:00 AM(UTC)
tb19
I've had same problem on Kenmore Elite. To get a new seal you have to replace the sump. After 2 leaks, 2 sumps, a new diverter, a flow solenoid, lower rack wheels,.upper rack track, upper adjusters, within 4 years, I got rid.of this piece of junk. Whirlpool garbage installed in a lot of products now. No wonder Sears is going the way of the Dodo bird.
J_H
#55 Posted : Friday, August 17, 2018 12:18:08 PM(UTC)
J_H
From the dates on these posts, I guess I am one of the lucky ones who didn't have his Kenmore 665.12762K310 start leaking until it was nearly 5 years old. However, I am one of the unlucky ones who got the version with the grommet permanently affixed to the sump. Replaced the sump, replaced the diverter motor. Still leaks, and it's not just a trickle. What an abomination of design this thing is.
Undecided about how to proceed. I have read the various posts - there is no easy way to create positive pressure to seal the grommet/shaft interface. I'm going to try to find a tight neoprene gasket & silicone and hope for the best.
tb19
#56 Posted : Friday, August 17, 2018 1:51:05 PM(UTC)
tb19
I fixed mine by buying an LG, that was 1/2 as much as this POS. Gone 4ever. Just like Sears
Mango123456
#57 Posted : Monday, June 14, 2021 2:07:10 PM(UTC)
Mango123456
I had this problem. I replaced the grommet/seal but was confused to find the new one loose and leaking. Wrapped some PVC tape around it, reinstalled, and now the dishwasher works correctly with no leaks.
6 Pages«<456
