2 Pages<12
jjddgg
#11 Posted : Tuesday, July 25, 2017 5:49:14 AM(UTC)
jjddgg
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Most likely you have there a stocked drain pump. It's underneath on the right side. Remove it and check inside.
I had a 'humming noise' when water was supposed to be expelled at the end of the cycle.
I took the pump out and took it apart. Turns out a bobby pin had worked its way all the way to the pump and had stopped it. Re-assembled and reinstalled the pump, tested it, and the machine works again!
Thank You.
2 Pages<12
